Would the stock coil be okay, or should i buy a kit with stiffer coil?
L Live2Cycle87 · Registered Joined Feb 20, 2011 · 71 Posts Discussion Starter · #1 · Feb 20, 2011 Only show this user Would the stock coil be okay, or should i buy a kit with stiffer coil?
F foresterxt · Registered Joined Oct 20, 2008 · 27 Posts #2 · Feb 20, 2011 Only show this user You might want a stiffer spring. I'm 172 lbs and feel like I'm just about on the edge of bottoming out. Live2Cycle87 said: Would the stock coil be okay, or should i buy a kit with stiffer coil? Click to expand...
L Live2Cycle87 · Registered Joined Feb 20, 2011 · 71 Posts Discussion Starter · #3 · Feb 20, 2011 Only show this user Thanks for the input Do you think I should go with stiff or ultra stiff coil set?
mullen119 · Registered Joined Aug 30, 2009 · 4,728 Posts #4 · Feb 20, 2011 Only show this user I would think you would need the extra firm spring.
