It's not as complicated as it sounds if you sit back and take a breather.
Have faith, brother. All is not lost, however. There are literally dozens of websites out there were people share their GPS tracks (many are discussed in other threads on this board). You can download them, put them into your 705, and the GPS will route you on them. It doesn't work the same as the car GPS, but it will point you in the direction you need to go to stay on the trail (or return to it if you make a wrong turn). The GPS just doesn't know intersections on the trails, so you won't get warnings to "turn left" at the next intersection.
Sometimes you'll encounter trails where you can find no existing data. That may happen more or less often depending on where you are. In those cases, you will have to "map" the trail system yourself if you want a reference for the trails. The basic way to do this is to record some of your favorite rides so you can follow them. It's a bit more tricky if you want to map the whole network and install it onto your GPS just as a reference so you can free navigate the trails and not get hopelessly lost. Doable, but I wouldn't recommend it until you've got some practice under your belt.
The gpsfiledepot maps are nice. I have Garmin's 100k topos and City Navigator. I don't use either on my 705. I only use gpsfiledepot maps on my 705. You can't get better than free. And better yet, if you don't like them, you can make your own maps that include whatever data you want (including trails). The process is involved and fairly tech-heavy, but doable.
Welcome to the world of GPS tech. The GPS receiver is only just the beginning of what you can do with it. Computer software makes your options explode and the sky is the limit.
Some mapping packages have SOME trails on them, and I hear some of the newer Garmin maps make them routable somehow. I don't know how that process works, but I DO know that there are not many trails on those maps, anyway...so for mtb use they won't help much. MTB trails are often too new to be included in their entirety. You might have a segment, but nothing else.
Planning anything on your GPS is going to piss you off in short order. If you want to plan a route, get some good mapping software (Topofusion, NG Topo!, or some other package) and plan your route on your PC. From there you can send it to your GPS and have something you can use for reference. Roads data are included on topo maps (just like paper maps) but are frequently not routable. That will probably change, since it just makes sense to put both on the same maps for ease of use.
You can install multiple mapsets onto the GPS at once (more than just two). You need to have them all either on your pc (as in the gpsfiledepot ones) or on discs. It won't work if you buy them on memory cards. But, keep in mind that you can only EITHER route on-road or off-road. You cannot do both on the same trip. It is a setting of the GPS. If you tell it to route on road because part of your trip follows roads but the rest is on trails, then when you are on trails, the GPS will try to make you follow the roads. Very messy. I suppose you could switch the GPS yourself to routing on road or off road when you switch surfaces, but that setting on the GPS is kinda buried and you'd have to stop, fiddle with the GPS, before you could continue.
