Prebent in the JD2 and then into the smasher!!Hey;
Are you starting with straight or bent tube here?
What kind of bend quality are you getting with that JD2? There are so many mixed reviews about those benders, but for the price and the versatility I can't help but be tempted.Prebent in the JD2 and then into the smasher!!
The JD2 is made for thicker walled tubing but it will bend thinner up to 25-30 degrees butWhat kind of bend quality are you getting with that JD2? There are so many mixed reviews about those benders, but for the price and the versatility I can't help but be tempted.
If I can get 15-20 degrees out of 7/8" .035 I'd be happy.The JD2 is made for thicker walled tubing but it will bend thinner up to 25-30 degrees but
Can dimple the tubing to much that's what happen to this one so it made a piece for the
Smasher!
Desired but I did noticed that it tightened the radius also.Hey;
Do you start with the desired degree of bend, or something less?
