First go out and get a good portable multi tool like a Topeak Alien or the one made by Crank Bros -- a must for fixing stuff on the trail and at home. That will get you all the basics, then you can expand. SMT is right on when he suggests you get a good set of metric hex wrenches and screwdrivers. As you learn more about fixing bikes, you should pick up a chain tool, pedal wrench, and maybe a crank puller/bottom bracket tool (these last two are specific for the type of cranks/bb you are running). Later on, you will get into stuff like spoke wrenches, freewheel tools, chainwhips, etc. Just buy them as you need them, or, if you have the money to burn, pick up a Park tool set and get pretty much everything you need at once. Park also makes the best stands IMO ($), but you can also get similar models from performance, etc. Expect to pay around $100 for a good stand.Lickqid said:I need some tools for my bike, my dads old road tools are just no help whatsoever. I also need a stand. What tool kit would you guys recommend for someone just needed to do regular matinence on my bike? ALso what stand? Thanks
Exactly. You get what you pay for. Off-brand tools are crap for the most part. Stick w/ Park, Pedros, Crank Bros. -you'll only have to buy them once.flatulentfox said:yeah, 90% of the things you will need to do can be donw with allen wrenches. other than that, definitly a chain tool, cable cutters, crank pullers, pedal wrench, etc. if you have several bikes you maintain and work on regulalrly, a headset press will pay for itself fairly quickly. one caution: DO NOT try to save money by buying cheaply made tools. they will brake quickly and will not work as well as a quality tool. in the end, you will end up buyign a better version anyway, go ahead and buy it now. if you simply cannot afford to buy a certain tool, just take you rbike to the shop for that task (or borrow one from someone) until you can afford it. cheap shi ty tools will just make you mad and make things harder.
I didn't know it was called a "balldriver" but this is the kind of hex wrench set you want. The are preferable to a straight non-ball ended hex wrench because you can grab a bolt from an angle. I haven't seen them at Sears, but there are good inexpensive sets you can get from your LBS.SHIVER ME TIMBERS said:these are a good start
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=41003
these are good for home repairs
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92527
great advice....cheap stuff ends up stripping your bolts tooflatulentfox said:DO NOT try to save money by buying cheaply made tools. they will brake quickly and will not work as well as a quality tool. .
sunnyracegirl said:I
My basic tools:
Ice Toolz mulit-tool for the trail (complete with chain tool AND bottle opener)
QUOTE]
oh and the bottle opener works great...tried it out on a few Stellas and Becks...where are those pictures Laura???
Ultimate Pro Stand rocks, nice adjustability. I got a metric multi tool at Sears for like $8.50, then grabbed another single 8mm for my forks. I keep that, a leatherman, and a chain tool in my bag when riding. I end up getting tools as I need them.....You'll be surprised one day when you see the pile you have accumulated!SHIVER ME TIMBERS said:great advice....cheap stuff ends up stripping your bolts too
true. and your toolbox quickly becomes too small.xdefx said:You'll be surprised one day when you see the pile you have accumulated!
I haven't seen the Ultimate stand, but I have a Parks PS-1 and it's pretty nice and looks sturdy.austinb89 said:im in the same problem you are in my freind, can anyone recommend a good bike work stand that will do well for downhill bikes( upper 40lbs).....and i dont mean to jack ur thread or anything
