1 - 3 of 3 Posts
Jersey said:
i just set up my Oro Puros and i noticed that the lever travels a lot to fully engage the pads on the rotors. i have the dial set all the way to fix the problem, but there is still too much lever movement.
any suggestions?
i felt the same way when i got my 24's. 'Hmm, travels too much" i said. but after a while i realized the travel helps in better modulation..
anyway if you want to decrease the lever throw before contact, i think you will need to bleed more DOT into your brake line. ask [email protected] on this..
1 - 3 of 3 Posts
