what a blast - and a workout!
some things that are concerning/some questions/observations:
some photos and stuff of what i encountered to give you all an idea. this is in Westchester, NY. i've been told there are easier parks to start with. but again, i will reiterate, i am already hooked!
the steed:
the features:
the carnage:
- riding over features, even very small ones, was pretty scary. i found myself questioning what speed to hit them at, would i even be able to make it over, should i pedal while rolling over them, etc. if it was too questionable i just walked over/around.
- i found myself really struggling with shifting - not only when and where but even which lever did what. for whatever reason it wasn't sinking in which lever shifted up and which down.
- to that point, there were a few times when i shifted while climbing as well as once instance where i was shifted all the way down and, not realizing it, was attempting to shift past that. hopefully i didn't mess anything up but it felt and sounded fine after my ride.
- braking is also something i need to get used to. when to use which brake. when to brake at all? is it normal/OK to brake to trim speed on downhills and/or when approaching tight trees?
- i definitely need riding gloves.
- i found myself (probably obviously) enjoying the more flowy sections vs. the more technical stuff.
the steed:
the features:
the carnage:
