To the person who pm'ed me about Fuel pivot specs....
681 Views 2 Replies 2 Participants Last post by  Fuelish
could you please respond here or pm me again ??? I truly f'ed up and deleted the message before I clicked on your e-mail link to open my e-mail program....OOPS !!!! Oh, well.....Sorry 'bout that - and, just so ya know, Trek sent it in .pdf format, so you'll need to download Adobe Reader to view it (free download). Again, sorry about that...will send 'em as soon as I hear from ya again....
1 - 3 of 3 Posts
loosening swing arm pivot problem...
It wasn't me who PM'd ya, but speaking about pivots... My swing arm pivot at the frame tube has some up/down slop to it, started about 3-4 mos. after I bought my Fuel 90. my LBS offered to tighten it to torque spec but it only lasted a few more mos. Then they added loc-tight and it's been 4 mos. and it's starting to loosen again! the movement looks like wear, not loosening. anyone have this problem? I need all the plushness I can eek out of my Fuel rear susp! :confused:
Could be your bushings are worn out - have you ever serviced them ??? It should be easy to tell if it's play in the bushing or just loose pivot bolts - if bolts are torqued to specs, then it's bushings (.....or - banish the thought - perhaps cracked rear triangle???...hopefully not...) Good luck
1 - 3 of 3 Posts
