...that is my question!
I have a 01 Zocchi Z1 MCR that seems to have lost some of it's plushness. The sag is set to the correct amount but there seems to be a lot of travel used up when I'm riding on flat ground. I was going to do an oil change (haven't done that in several years) to see if that would help. As I was going through the manual, I looked at the problem-resolution chart. It had my problem in there and said that the bushings could be worn out. I priced out the bushings, seals, and oil (that I already got) to do a complete rebuild and it's a little over $100.00. I can keep the oil for future use, but do you think it's worth the rebuild? Do you think a rebuild would correct my problem? I do like the fork a lot but is it just time to upgrade???
Thanks for the advice in advance!!!
