1 - 11 of 11 Posts
I've read a lot about the other Motobecane fat bikes. Sound like real nice bikes minus the hubs.
This bike has less than 20 miles on it. Price is $850, appears it sold for around 2k two-three years ago.
Ride mostly dirt roads and equestrian trails with lose sand. Starting to get into riding more with my boys getting older and riding with me.
I currently ride a pretty basic orbea hardtail 3x9 even. Ready for something different but I'll keep the hardtail.
Here are the specs on this bike.
Save up to 60% off new Motobecane 2018 Titanium NightTrain Bullet SRAM 2x11, Rockshox Bluto Suspension Forks Titanium Fat Bikes, Mountain Bikes
In case someone doesn't to click.
And a bluto fork
RACE FACE CRANK,TURBINE 2X11, 24/34, 2x11SPD FAT BIKE , Crank 175mm
Bottom BracketRACE FACE BB-100mm BSA English Threaded Outboard Sealed Bearings
Pedalsn/a
Front DerailleurSRAM FD GX LD 2X11 BOTTOM PULL
Rear DerailleurSRAM RD GX 2X11SPD LONG CAGE BLK
ShiftersSRAM SL GX 11SP TRIGGER BLK
Cassette/FreewheelSRAM CS PG 1130 11-42T (2x11)
ChainKMC X11SL SUPER LIGHT NARROW CN 1/2"x11/128"x114L.W/HOLLOW PIN , INCLUDING CL555R NP REUSEABLE LINK
HubsNOVATEC D201SB-15 ALLOY FRONT DISC HUB 32H:15mmx150mm FOR FAT BIKE, 2 PRECISION BEARINGS, ANOD. BLACK, F/HUB AXLE ROCKSHOX 15x150 Maxle Lite
R/HUB(FH) T NOVATEC D202SB-X12MM-S4S ALLOY REAR DISC HUB W/ STEEL CASSETTE BODY 32H.OL:12x197MM CRMO AXLE, 4 PRECISION BEARINGS, 2RS ANOD. BLACK, R.HUB THRU QR C KINESIS ALLOY 7075 QR 12x229xM12xP1.75
Spokes14G STEEL STAINLESS W/BRASS NIPPLE
RimsSUN-RINGLE Mulefüt SL 80mm,32H, W/FV BLACK ANOD. W/ BIG HOLES ( 32mm ) *See FAQ page for Tubeless system setup
Tires/TubesMAXXIS MINION 26 X 4.80, FBF / FBR 60 tpi Folding Bead
BrakesSRAM Guide RS HYDRAULIC DISC BRAKES, W/POST DISC MOUNT, 180mm ROTOR, GLOSS BLACK
Brake LeversSRAM Guide RS HYDRAULIC DISC BRAKES
HeadsetORBIT 1.5 ZS , FOR 1-1/8"/1.5" FORK STEM , Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower,w/Std 12.3mm top cover (H2051B) , W/39.78 BALL RACE
HandlebarRITCHEY MTN COMP RIZER (Low Rize-20) ( C:31.8mm ), ALLOY 6061 RISE H/BAR(UPSWEEP 17° , BEND 9° ) B/CENTER: 31.8mm.R/W:20/710mm. BB BLK
StemRITCHEY STEM COMP 4-AXIS 84/6D ( C:31.8mm ) ALLOY 6061 "TIOGA-OS" A-HEAD STEM.EXT:(6°)70/80/90MM FOR 39 / 45 - 48 / 53CM ,C/S:31.8x28.6x42mm. BB BLK
Tape/GripWTB Dual DNA Compounds, Classic Logo
SaddleWTB Rocket COMP, Satin Steel Rail, PU Leather Cover
Seat PostRITCHEY SEATPOST COMP 2B 350/400 OS , ALLOY BB BLK S/POST W/ALLOY BB BLK HEAD 31.6x400mm
What would this bike weigh in large? If I get it I think I'll take it to a shop and have them make it tubeless.
Should I pull the trigger? Going to start riding more single track this fall also.
Thinking if I didn't like it I could sell it for the same amount or a bit more come winter time.
Sounds like a good deal to me. The only people that don't like the Motobecane bikes are people who don't own them. They used to be heavy, mine are- we have two of the original FB4's, but the one guy I know that has a Ti version loves it. Only issue he's had was the bottom bracket. Anyone can get a bad one. I killed one on my Krampus in 3 months.
Sent from my Pixel 2 XL using Tapatalk
if it fits and you like the way it rides/handles, go for it. Upgrade candidates in the future would be shifters and brakes.
Elitest thrill junkie
Not sure I'd go for that, it's a pretty low-end build, not terrible by any means, but if you really need a fatbike, I guess it would do alright. Ti as a frame-material never materialized as the "wonder-material" it was made out to be in the 90s. It generally cracks at a higher rate than aluminum due to the tightly controlled conditions required for welding. At that price though, it looks hard to go wrong, a decent fatbike usually starts at ~1500, so you are definitely making out compared to that.
Discussion Starter · #8 ·
So after watching some videos on fat vs regular mountain bikes I’m
Really torn. Not sure it’s the right fit. Lots of people love them year around.
$750 is now the agreed price. Bike fit about perfect and it felt pretty good.
That is a STEAL!
I bought a 2016 new and have hammered on it for the last 3 3/4 years and it's been rock solid. It takes every bit of abuse I can dish out and it keeps on going. I enjoy it so much that I sold my FS Salsa and just ride this. I bikepack with it, hammer down trails bouncing off nearly everything and anything, and even road ride with it. I have the large size and it weighs in at 37 pounds with the Bluto, still setup 2x10 (22/32 x 11-42), and with 100mm Turnagain rims running Bud/FBR in summer and Johnny5's in winter. My road setup is BFL's on the stock Mulefuts with 24/38 x 11-36 and it weighs 35 pounds.
I had to replace one RS brake caliper due to the sticking issue they had, but it was an easy fix. I replaced the bearings on the rear Novatec wheel but it turned out to be the bearings in the driver and not the wheel. Tubeless is super easy and it holds no matter what the pressure, I have run mine down below 1 psi with no issues.
I did replace the creaking BB with a Phil Wood almost 2 years ago and it's been flawless. I have never heard of one cracking and if mine hasn't I doubt any would. I've had the bike weigh almost 100 pounds with bikepacking gear on it, towed a trailer carrying 130 pounds, and even had to bail off it on a bridge onto some rocks and all it did was scratch the handlebars.
I can't say enough good about the bike and the build, and for that price, you can't touch it with anything else.
Oh yeah, I also live on the coast of Maine and ride it on the beach often. I love that it can't rust and nothing besides the chain has suffered any ill effects.
Tire Bicycle tire Wheel Bicycle wheel rim Bicycle wheel
Tire Wheel Bicycle tire Bicycle wheel Bicycle wheel rim
Rim Spoke Bag Fender Automotive lighting
Bicycle frame Bicycle tire Tire Bicycle wheel Bicycle part
Discussion Starter · #11 ·
Nice dilli! Crazy on not riding your FS anymore.
Figure I could sell it for more than what I’m buying it for if I don’t like it. It’s weird he hasn’t sold it. He has been lowering the price for nearly a year and fat bikes are semi popular in Colorado.
1 - 11 of 11 Posts
