The thread below by Andy N prompted me to share my thoughts on the TNT rear end. But, rather than share with you overall impressions (which really mirror what others have experienced), I'd like to just focus on climbing, for now.
I really wanted to get a few more weeks under my chamois before I posted this.
But since it is being discussed, below....here's my thoughts on the TNT rear end in regards to climbing.
Like AndyN, I use the Waterfall climb at Noble Canyon to gauge and compare any changes that I make to my bike. If I change frames, bar height, tires, shock settings, etc. this is the one climb where any backward moves on component choice or setup, will be readily apparent.
The waterfall climb is very steep and long. It is extremely loose. There is hardly any run in leading up to it and the tight righthander leading in, is filled with sharp pieces of granite which tend to scrub your speed or wash your front tire.
It goes steep immediately after the right turn. 1/3 of the way up you hit a series of steps and ledges. If you lose your momentum and stall, your rear tire will spin out and you're done. Dabbing to the right is not an option. You will freefall 50 feet into the canyon below. I've seen it happen plenty of times.
Most riders dismount and walk this section. They are probably the smart ones.
I've linked to Fooriders for 3 vids of the waterfall climb.
I've posted this video before and you've no doubt seen images of this climb many times.
http://www.fooriders.com/webmain/index.php?name=PNphpBB2&file=viewtopic&p=279397&t=55970
The first vid is my old red 5 spot with Horst Link. (Romic rear shock).
The second vid is my new 5Pack with the TNT (Fox DHXa) rear end.
The third vid is Rodman on a late model heckler (5th elephant rear shock).
Of note, is the way Rodman approaches this climb, he is in a low gear. Granny up front and 1 or two in the rear. So, he's hitting this climb in an extremely low gear, similar to what AndyN describes below. You can see him stall as soon as he hits the steep part and the rear wheel loses traction.
I think that attempting these types of climbs(like what AndyN depicts), in too low a gear, regardless of what type of rear end or bike you have, is going to hamper one's results.
So, I'll let the vids speak for themselves as far as comparing the TNT rear end to a Horst link.
It makes no difference to me whether I have the Horst link rear end or TNT rear end. The results are the same. I adapted to any nuances almost immediately with the TNT rear end.
