except once again you fall into the category of "you don't want that to happen" the amount of force that it will take to destroy a tungsten ring most likely means whatever is in the immediate area is going to be destroyed! i like the Ti bc it's so light also i've been told but have not tried it that ti rings are not too hard to be cut off in the event that they need to be(think third degree burns swelling your fingers into suasages), whereas the tungsten ones are at the outer reachs of emergency room cutting technology.Minjin said:I'm not one to wear rings but if I did, it would be tungsten, not titanium. You're not likely to ever scratch a polished tungsten carbide ring (most companies also warranty against it). And if you do, you've got other things to worry about (like your hand). Tungsten also won't pinch your finger should something crush your hand. Titanium will deform and pinch and need to be cut off, whereas tungsten will crack and crumble away. Lastly tungsten has a bit of weight and some people like that.
More than a bit of weight. Sister-in-law's new husband's tungsten is easily twice, if not more the weight of my ti band. It is a good looking finish though.Minjin said:. Lastly tungsten has a bit of weight and some people like that.
I'd recommend against tungsten.Minjin said:I'm not one to wear rings but if I did, it would be tungsten, not titanium. You're not likely to ever scratch a polished tungsten carbide ring (most companies also warranty against it). And if you do, you've got other things to worry about (like your hand). Tungsten also won't pinch your finger should something crush your hand. Titanium will deform and pinch and need to be cut off, whereas tungsten will crack and crumble away. Lastly tungsten has a bit of weight and some people like that.
