Just make sure to use Never Seize during assembly .
I think you're right.sasquatch rides a SS said:Just ride you bike and have fun.
That's why I posted this in Tooltime instead of Weight Weenies - to get unbiased opinions. Someone may still chime in with ti is cool, but I want to hear all sides. It is not just about being light (I'm 6 lb overweightnov0798 said:Yea I dont see any value in Ti parts, other than bling. Dont think youll ever notice a difference in weight other than your wallet.
Very interesting! That limits ti fasteners to brake lever and shifter clamps, and a few other small fasteners which undergo minimal shear stress. In that case, why bother? That's also in line with reports of ti pedal spindles shearing.customfab said:Ti fasteners are very reliable if they are forged like steel bolts. Almost all of the TI fasteners you will find for bicycle applications are machined though and do not have the needed strength. If you knew what forged Ti fasteners cost you wouldn't have even thought about it.
Exactly, why bother? It's an aesthetic thing more than a performance item, in most cases. Although I do like the subtle look of ti in different areas...Shuteye said:Very interesting! That limits ti fasteners to brake lever and shifter clamps, and a few other small fasteners which undergo minimal shear stress. In that case, why bother? That's also in line with reports of ti pedal spindles shearing.
best thing to ever happen to that pedal!jtmartino said:Speaking of Ti, I just bought a bike that had Ti spindles on the Eggbeater pedals. One of the spindles had seized to the crank, and the previous owner had rounded out the flats on the inside of the spindle with a hex wrench. What a tremendous PITA it was to remove that thing...the spindle still has the hex-shaped drill bit that I jammed into it to provide enough grip to remove the pedal...
Snorted my drinkcustomfab said:best thing to ever happen to that pedal!
Not bored at all, thanks for chiming in - the first positive words in favor of extensive ti use. I see a metallurgy debate brewing, however, regarding forged vs machined. I haven't googled it, but remember reading something about molecular (or atomic?) alignment when forging.Joza said:Oh, so many words, I hope I didn't bore you to death.
99% of the Ti fasteners listed on ebay are made from CP Grade X which is not worth the headache. Buyer beware.......seizing will be the least of your problems.Shuteye said:Is there a problem with titanium seizing, and are the Chinese ti bits that you can purchase on eBay of decent quality? I searched this but didn't come with a specific thread.
Duly noted. Thanks! If I have to classify, I ride all mountain - 29 lb, 5" travel with plenty of tools and water. Considering all the input on this thread, I think future ti is out for me unless supplied by the manufacturer with an upgrade component I purchase.mtnbiker4life said:99% of the Ti fasteners listed on ebay are made from CP Grade X which is not worth the headache. Buyer beware.......seizing will be the least of your problems.
Ti is cool. AndShuteye said:Someone may still chime in with ti is cool...
Metal doesn't work like that skipper. There are grain structures to worry about and that is pretty complex stuff that I really only understand the basics of. What you need to understand is that a forging orients the grain in an ideal way. When you machine something from a billet (solid chunk) you disrupt this grain structure and wind up with a weaker part. That part may still be strong enough but it is a compromise.Joza said:Well, I would like to contribute as well.
As far as my experience with Ti hardware goes, I'm more than satisfied with it. The weight is between Al and steel and strenght is more likely to steel. It doesn't corrode and looks awesome. Btw, I don't like Al screws because of their week heads - I usually end up with a messed up allen hed - never happened to Ti ones.
And about the forged vs. fabricated srews - I don't think that forged are necessarily stronger. The fabricated ones are made out of solid blok that someone CNC (or whatever) to the designated shape. So if the solid blok is OK, than the srew should be OK as well. I have experienced a lot of steel bolts that were 'forged-made' broken like nothing - drilling was needed to get them out, this luckily never happened to mine fabricated Ti ones (so far).
It's obvious by the information in your post that you do not have even the basic knowledge of material science. By all means I am no expert, meaning my ME degree is not focused on material science but I know enough to know you're mislead.Joza said:Well, I would like to contribute as well.
And finally to the eBay Ti srews/bolts, they are fineAnd for a reasonable prizes. I have swapped all the steel bolts to Ti, except chainring ones - Al. I'm a bit of a weight weenie - true that, but my bike is well under 2000USD and around 9kg (hard tail).
Edit: And the seizing - you should use some anti-seiz. Same thing applies far all bolts (at least for me).
