I too have noted through the years the difference in getting a smaller diameter tire mounted on both 26" and 700c.
But when I switched to Nano's in 99' I pretty much tossed my tire levers. I mean try and mount/dismount something like a 25mm road tire and you are looking all over for the tire levers, whereas on the same rim a Nano would slip right on with finger pressure? But I got a flat (my first ever 29" one) trying out an early GF Mt. Tam mounted with Notos tires due to a small nail and could not get the tire off the rim without resorting to using my cool tool philips/hex key, very gingerly I might add. But that is the only 29" tire I have had to use a tool on since, including other Notos.
Given the fact that a 700c rim standard bead diameter is 622mm I am assuming there has to be a certain degree of +/- involved but it can't be much. I have always just thought it had to do with the extra casing involved with the larger tire being more supple but I am not by any means the expert and ready to learn
Oh yeah, the Titan Tour rims should be just fine and you know the price is right.
