nevegal sticke upfront(2.35) and excavator(2.10) in the rear for me. Though one of my friends runs nevegals front and rear. Sticke upfront and dtc in the rear.
Tire pressure could be causing your problem. What pressure are you running? Too much pressure can cause the best tire to slide on anything it hits. For my setups with tubes I run around 40 psi. If your pressure is too low with tubes you run the risk of pinch flat (looks like a snake bite). On my tubeless set up I run about 35 psi. Generally, lower pressure = greater traction and higher pressure = lower rolling resistance. The key is to find a balance between the two. I have found that just a few psi can make a huge difference in ride quality.FotoJesse said:Any body got some suggestions for tires that are good on rooty trails? I am just getting started and the Bontrager Connection Trails that were oem on my bike slide off of even the smallest roots. A friend gave me an ancient Univega with the original Kenda tires (no model name) that grip better over the roots than the Bontragers on my Trek. I was following my girl who was riding the Univega and over the same spots those old Kenda's were hooking up and my Bonts were slipping all over the place.
Great info, but I would also like to add to this by saying that lower pressure does add to rolling resistance considerably as well as adding to traction. Forty psi is a comfortable PSI for all around trail riding. If you can get away with it, when you are riding on root bound trails, try running around 32 to 35 psi like msimmons mentioned above. Also, getting tires more suited for your style riding would help as well. Some tires just suck in regards to traction on roots. Nevegals are super great tires for gripping many different type terrains and run very well on lower tire pressures, but there are others as well. Good luck bro! :thumbsup:msimmons said:Tire pressure could be causing your problem. What pressure are you running? Too much pressure can cause the best tire to slide on anything it hits. For my setups with tubes I run around 40 psi. If your pressure is too low with tubes you run the risk of pinch flat (looks like a snake bite). On my tubeless set up I run about 35 psi. Generally, lower pressure = greater traction and higher pressure = lower rolling resistance. The key is to find a balance between the two. I have found that just a few psi can make a huge difference in ride quality.
So if you haven't already, try this and maybe you can get some mileage out of those bontragers.
All good bro. I weigh in around 215 - 220 geared up and run between 32 to 40 psi tops. If I am riding on smooth hardpack or road, I will run 40 to 42 tops (45 to 50 for urban tires), but the more gnarly the terrain or if I am DH/FR, I will run 32 to 35 tops. I am familiar with those Bontragers, and they are OK. Try to stick with a tire tread more versatile for your riding style or discipline. Try the lower pressure, if it works for you, then that is great, if not, fly with a more versatile tread tire. Lots of great tires out there. A good fast rolling tire that sticks to wet roots and rocks for FL is the WeirWolf 2.3 AM & Schwalbe Fat Albert 2.4 for starters. Anyways, good luck bro. :thumbsup:FotoJesse said:Yeah I have lowered the tire pressure down to 42. I will give it a try at 40. Thing is I am 200lbs geared up and I wasn't 100% sure about running the lower tire pressures at my weight. Thanks for the suggestions.
LS39 said:FotoJesse, I'm a 155 lbs rider and ride Hanna everyweekend and I've found that the fastest set up for me is Kenda Excavator 2.1, 15-20 psi on the front and Maxxis Crossmark 2.1, 40-45 psi rear, rear shock set open and 10 psi over the psi suggested for my weight. This set up gives me the best balance between speed, traction, rolling resistance, efficiency and comfort.:thumbsup:
