1 - 4 of 4 Posts
Hi. I'm a novice when it comes to my bike. I just got new Nimbus EX tires for my Mtn Bike for when I'm city riding. I took off the Panaracer Fire XC Pros I had on them, put the new Nimbus' on, inflated the tubes, but I now have a "flat" part on each tire. The tires are round except for one part on both of them, where they're flatter by about a 1/2 inch. Can't find any rhyme or reason for it, the flat part is in a different location for each tire in relation to the tube valve, I measured the rims (Mavic Crossroc UST Tubeless) to make sure they were round, theyre fine. Anyone have any idea whats wrong? Are the tubes or tires seated wrong somehow? Is it possible the tires are just defective?
tire/rim combo
Some tire/rim combinations don't work too well. It is possible that this is the problem. If it is, the way to fix it is to inflate the tire slowly, and every 5psi or so, wobble the tire. Go around the wheel and push the tire side to the side on the rim. Go all the way around the rim, and pump some more air in there.
uofabill
Possibly not seated properly
Sounds like yer using tubes? That's not a problem but your tires may not be seating well all the way around the bead.
You can air them up to about 60+ lbs and see if you hear the bead "snap" into place. Or, lube the bead all the way around on both sides with dish soap and water then reinflate.
You can usually look closely at the bead and see if it's seated completely on the rim.
I doubt that you have defective tires.
Premium Member
Agreed. Some standard tires and tubes are tough to seat the beads on UST rims. The above advice is right on target.
1 - 4 of 4 Posts
