HaulAss said:
I'm wanting a new rear tire on my bike, the old one is getting pretty bald from just using the back brake and skidding to a stop on asphalt. Their 26 x 1.95 specalized tires right now, can I go up to like 2.0 or 2.3 and just adjust the brake diffrent?? I'm thinking about getting timber wolfs, anyone give me any advice on which model for some trail riding and some street getting there? Or if I should get a diffrent brand.
squash's advice is good. measure the width of the current tire at the widest point (it could be the casing or the knobs, but knobs are farther into the frame so that's a good place). It's probably something like 1.9", if you've got a 1/4" or more on each side, you're likely fine to go with a 2.35" tire.
2.35" tires are usually high volume, so are much larger in diameter, as well as width.
check out shiggy's tire spec site to see the actual widths of many tires (they're often much narrower than stated).
Oh, I'm not familiar with the timberwolf tires, but I suspect they'd be pretty slow on pavement... try the search function in this forum for some info.
Without more info on your riding style & terrain, it's hard to recommendo a tire.
