Just curious, are you running the LTs with the inner peace sidewalls?Menso said:I'm going with the Weirwolf LT 2.55 also. Front and rear, and ghetto tubeless, Menso-style. Electric tape rimstrip and valve core cut out of flatted tubes. I rode at the gathering with the same tires, and they worked great. They're a little sketchy on loose stuff, but they break free predictably so that trait can actually be used advantageously to line up the wheel through a turn.
What size tires are you running front and rear?I really like the performance of the SB8 but i have never ridden with the Nevegals.francois said:You want something grippy up front yet fast. You want something durable, yet light.
I would run the Nevegal up front and the Kenda SB8 in the rear.
The key is to run them or any tire tubeless and/or with Stans Fluid. Flats are the enemy!!!
You want a tire with girth so you can cushion the blows. Also, you don't want to run excessively high pressures since it's easier to slash a tire. Lower pressures with tubeless give you give you grip and control.
fc
I like the Nobby Nic UST a lot. You're right, they're big, light, grippy and fast, but I cut one (2.25") really badly, right at the bead, and Stan's couldn't seal it. The terrain wasn't that harsh. (Pine Mountain) I'd like to think it was a fluke but I've read similar things about the NN UST. I wish they used a stouter casing. I'll run them again for fun, but in a race it's too risky. Plus, they're pricey.francois said:I would also recommend the Schwalbe Knobby Nics, Tubeless with Stans Fluid. They are very big, light, grippy AND fast.
Two of my test riders rode them at Downy a couple of weeks ago and they were untouchable. Of course they were great riders too.
fc
Sick! Ghetto tubes rock. I have been running them for years and they work fine if done properly. I use packing tape and then a few spins of Electric tape. I just ordered 2.1 nevegals for the xc. I should got the 2.3 now that i'm reading this.:madman:Menso said:I'm going with the Weirwolf LT 2.55 also. Front and rear, and ghetto tubeless, Menso-style. Electric tape rimstrip and valve core cut out of flatted tubes. I rode at the gathering with the same tires, and they worked great. They're a little sketchy on loose stuff, but they break free predictably so that trait can actually be used advantageously to line up the wheel through a turn.
That is hella ghetto.. haha22b22 said:Ghetto Tubeless how-to videos courtesy of Linga115 here on the forums. After watching, I did it easy.
part 1:
part 2:
If you've ridden the tires a few times with tubes, they shape and the beads will seat up better (based on my incredibly large number of attempts - 2 new tires and 2 gently used ones - the used seated quicker and easier). This may not hold true for all tires, but for me it did.
As far as I can tell, no. I can't find any label indicating "inner peace".MrCrash said:Just curious, are you running the LTs with the inner peace sidewalls?
2.1's are fine; I used them with success for the last two years. I'm going with the LT because of the lower rolling resistance and better grip at lower psi on the climb. I've always found the Nevegal to be a crappy rear tire for loose fireroad climbs.mtbjtd said:Sick! Ghetto tubes rock. I have been running them for years and they work fine if done properly. I use packing tape and then a few spins of Electric tape. I just ordered 2.1 nevegals for the xc. I should got the 2.3 now that i'm reading this.:madman:
I only take it no higher than 40lbs too for that reason too as I have read about the blow outs.mtbjtd said:That is hella ghetto.. haha
Just get some packing tape and electric tape.... so much easier. Liquid latex/windex for sealant.$60 for a gallon of all Latex or $20 for the smaller container. That will last you for months if not years. Stans magic crystals didn't do much for me.
He's nuts keeping his head right next to the tire filling it up. I've had one explode in my face once.
I take it back, Francis. I ran the UST 2.25 Nobby Nics yesterday. I put too much air in them and they were way too hard - 42psi maybe, the pump was inaccurate - but they did fine otherwise. I should have run them around 36-38. (I weigh 204lbs.) I also put a bit too much air in my shock and fork. Wish I'd done a proper pre-ride this year!morganfletcher said:I like the Nobby Nic UST a lot. You're right, they're big, light, grippy and fast, but I cut one (2.25") really badly, right at the bead, and Stan's couldn't seal it. The terrain wasn't that harsh. (Pine Mountain) I'd like to think it was a fluke but I've read similar things about the NN UST. I wish they used a stouter casing. I'll run them again for fun, but in a race it's too risky. Plus, they're pricey.
