1 - 20 of 27 Posts
· Registered
Allright, pulled the trigger on 575 and have been out for a couple rides. Handles like a dream, decends like a dream, my only complaint so far is that while the Maxxis Minions decend great (its a downhill tire), I can sure feel the weight and rolling resistance of them on the climbs.
Wanted to see if there are other Colorado front range riders out there that may have some suggestions for our loose conditions here. I've considered either Kenda Nevegal 2.1's, or Panaracer smoke & Dart combo 2.1, anyone else use those or have other good tire suggestions? Would like to save some weight and rolling resistance, but still have something that grips fairly well. Thanks!!
· Bad Case of the Mondays
I live in Boulder County, and ride all over the Front Range. I've run the Kenda Blue Groove 2.35 & Nevegal 2.1 combon (F/R) on my 575 for about 6 months now. I've been using the DTC compounds, which last a lot longer, but don't offer the same grip as the StickE compound.
I'm pretty happy with this combination, but as always I'm going to try something new next time. I'm going to give the Schwalbe Nobby Nic and/or Big Betty a whirl.
Larry from MtnHighCyclery was riding a set of Big Bettys the other day and I had to move off his wheel as the tires were throwing up serious roost, now that is what I call sticky! I've been told by numerous people that even though they are a bit heavier than the Nevegals, they roll better so it evens out. I've had good luck in the past with Schwalbe tires, so I'm gonna give em another whirl.
· Registered
I used Maxxis High Rollers for several week both Front and Rear. I'm doing trails like Green Mountin, Falcon, Waterton, etc. The rear wore out after only 200 freakin miles, and never had enought tractions IMO. I swapped the rear (only) for a Panaracer Fire XC Pro 2.1 and I'm really happy with that. I left the front High Roller on for now, but HAVE TO run it below 35psi or will wash out easily on loose stuff. I'm not impressed with the High Rollers at all, but they are OK for a front tire.
· Registered
I live in FL, but I've done a bit of riding around the Vail and Glenwood Springs areas. So, you can file this in the FWIW file. I found the conditions, loose over hard w/rocks thrown in, similar to what I ride down here. And no, it's not all completely flat and sandy in FL. I ride 2.3 Stickee BG/Nevegal combo and love it. I was riding near Avon last year on a loaner bike and kept thinking "[email protected] I wish had brought my own tires". The 2.1s roll a little better and weigh less, but the 2.3s inspire allot of confidence when the terrain gets nasty. A guy I know in Vail runs 2.1 Nevegals on his Blur LT.
· In my mind, I can do it!
Maxxis CrossMark's are light and fast. If you ride where you need excessive grip maybe not the right tire for you but they do seem to grip most stuff pretty well. I like them better than the Fire XC Pro's I had before.
· Registered
Discussion Starter · #7 ·
stick e vs dtc
Thanks for all the feedback so far. As for you Nevegal riders, how different have you noticed rolling on the dtc's vs stick e? And how comfortable on the nasty stuff with DTC.
As mentioned earlier, I'm riding mostly front range, (Deer Creek, waterton area, falcon, apex, etc.) just hate the feeling of sliding around on the downhills.
Never been to Florida Bob, but thanks for clearing things up about the hills, I figured that place was flat!
· mutaullyassuredsuffering
Nn/mud
The Nobby Nic's up front are amazing. They roll faster than most tires out there due to their casing design, yet grip as good or better than anything else I've tried.
I like the Michelin XCR mud in the front or rear also. They roll unbelievably fast for a grippy tire and are a little tougher than the Schwalbes.
Rolling resistance difference is substantial IMO. So is wear rate. I've used both compounds off/on for the last 1.5 years, and both have advantages and disadvantages.
For pure stick, confidence inspiring traction and you can handle their slower rolling nature the StickE is the way to go.
For decent traction, longer life and better rolling the DTC is what you seek.
· Registered
Stick-E vs DTC
Is substantial. The 2.35 BG's itself are relatively slow tires but really stick to rocks and has a very good volume. I run the big Kenda Stick-E's up front and a lighter tire like the Mutano 2.4 in the back. Having said that, I love the stickiness of the front tire and will sacrifice some climbing efficiency for it. If I wanted to get to the top of the hill first, I'd take the SS...
· Adobo Lover
To be honest with you, I really can't tell the difference. I just know the tread pattern hooks up well in a wide variety of conditions. I've ridden the UST(not a stick e or dtc) front and back, stick-e front, and dtc front and back. I do know that the stick-e looks a tad bit skinnier than 2.1. The UST seems the widest of the three.
· Registered
Just switched from Nevegals
...to Kenda Cortez 2.35's.
Rolling resistance is noticeably less, but they seem to hook like crazy. One thing I will say is that the sidewalls are THIN, but that's generally the case with lighter high-volume tires.
MM
· Registered
MM
If you are in the market for another pair of the Cortez that are slightly used (well under 100 miles or so), $40 and they are yours!!!
· Registered
If I didn't have the Kenda hook,
...I'd take you up on it in a second. Tires are really, really subjective and after only a few rides I'm finding myself liking these. I'd trade you for some similarly used Nevegals if that holds any interest.
MM
· Registered
Just asked my shop this yesterday
I just asked the guys at Road 34 in FC this questions yesterday. They are fans of Larsen TTs, which apparently are supposed to roll pretty well. Willy says he runs the Larsen in the rear with a Minion up front for more grip.
I'll probably try the Larsens or the CrossMarks next, or just go to Mtn High and do what Larry tells me :)
jg
· Registered
Email me your addy...
BelaySlave said:
I'll take 'em. I almost pulled the trigger on prodealing a couple of pairs of Nev's and BG's, but instead went with 2.24 and 2.4 Mutanos. So far, so good.
[email protected]
I'll send you the Nevegals. They've been ridden in Angel Fire, on Porcupine Down in Moab and just a little bit on the dust around here. If it's a fair trade send me the ones you have. If not, let me know what's fair. I know that if I keep them around here I'll just end up tossing them. I'd rather someone used them.
MM
· Registered
I just replaced my Maxxis High Rollers with Continentals. I use a Vertical Pro on the front and a Gravity on the back. Both are 2.3. I live about 2 miles from Waterton Canyon so that's my most frequent ride. Most of the rest of my riding is in the Vail-Eagle-Leadville area. The Contis track very well and handle bombing down the ski areas pretty well. no compaints so far.
1 - 20 of 27 Posts
