Probably. That's a considerable difference of rotational weight.Nim said:Will you really notice a difference in MTB climbing between tires, say with similar compounds and tread patterns where one weighs 600 grams and the other weighs 750 grams - a difference of 0.33 pounds per tire?
For sure if the light weight gets a pinch flat, and less so otherwise. Less rotating mess is better up to a point. You should consider your riding terrain in the equation and make sure that saving weight will not have a penalty in terms of reliability. YMMV, but I've only had pinch flats on small and light weight tires.Nim said:Will you really notice a difference in MTB climbing between tires, say with similar compounds and tread patterns where one weighs 600 grams and the other weighs 750 grams - a difference of 0.33 pounds per tire?
Is there such a thing as "rotational weight"? Yestlg said:Probably. That's a considerable difference of rotational weight.
Take a 600g weight and tie it to a string. Spin it around 50 times. Then switch to a 750g weight and spin it 50 times. See which tires out your arm quicker.
Ok, you try riding your bike with a 100oz filled camelbak, then try dumping that 100oz into one of your tires (they're about the same volume) and tell me you don't notice the difference.Chester said:Rotational weight is no different than normal weight UNLESS the bike is accellerating.
You did read the original post... right?In certain pure climbing situations where the bike is down to about 2 mph than quickly up to 8 mph and back and forth over large rocks and roots etc. rotational weigh will have a bit more effect,
Now that's just a silly comparison. If YOU read the original post, the question had to do with a difference of 5.3 ounces...not 100 ounces.tlg said:Ok, you try riding your bike with a 100oz filled camelbak, then try dumping that 100oz into one of your tires (they're about the same volume) and tell me you don't notice the difference.
I don't know about you, but when I ride, I'm always accellerating/decellerating. Your theory holds true if you're perhaps road riding at a constant cadence on a flat road.
Absolutely not. You said "Rotational weight is no different than normal weight". If it's no different, then it's no different. You wouldn't notice it whether it was 5oz or 100oz.Blue Shorts said:Now that's just a silly comparison. If YOU read the original post, the question had to do with a difference of 5.3 ounces...not 100 ounces.
"Ok, you try riding your bike with a 100oz filled camelbak, then try dumping that 100oz into one of your tires (they're about the same volume) and tell me you don't notice the difference."tlg said:Ok, you try riding your bike with a 100oz filled camelbak, then try dumping that 100oz into one of your tires (they're about the same volume) and tell me you don't notice the difference.
Semantics. Fine, freeze the water so it does't "sloch" around. And gelitin and solidify it. My point is simply rotational weight is different than normal weight.Chester said:OK.......adding 100 ounces.....about 6.33 pounds to ONE tire would cause more problems than a 6.33 pounds to your camelback......in part because the sloshing water falling to the bottom of the tire at slow speeds would cause tremendous friction rolling around in the tube rather than just because of the weight alone.
Duh. It was to prove a point. (see above) And it wasn't in response to the original post.You deal in the absurd.
You have scientific data to support this, or is it just your opinion from experience?Once that 150 grams gets up to a moderate climbing speed, the "normal" small and relatively slow changes in speed from 4 mph to 5 mph and back to 4 mph will have "relatively" little impact since the amount of total accelleration over the time in seconds involved is small.
If tested?But the amount of accelleration found in most climbing is, if tested, not nearly as much as most riders think NOR as fast as most riders think.
Ummm, where exactly did I say it was so extra important?One last question..........if you think "rotational weight" is so extra inportant compared to regular weight,
yes, because it will take calorie output to drive a heavier tire with a larger contact patch and higher rolling resistance..Nim said:Will you really notice a difference in MTB climbing between tires, say with similar compounds and tread patterns where one weighs 600 grams and the other weighs 750 grams - a difference of 0.33 pounds per tire?
Will you notice? Maybe. It can be easier to maintain climbing speed with a lighter tire. Whichever tires you use you will get use to the feel of the weight.Nim said:Will you really notice a difference in MTB climbing between tires, say with similar compounds and tread patterns where one weighs 600 grams and the other weighs 750 grams - a difference of 0.33 pounds per tire?
Look if you only think the ratio of "rotational weight" on a wheel is only 1.01 to 1 compared to other weight (frame, camel back, etc) then we are talking about nothing.tlg said:Semantics. Fine, freeze the water so it does't "sloch" around. And gelitin and solidify it. My point is simply rotational weight is different than normal weight.
If tested?
My position was simple. Rotational weight is different than normal weight. You can argue all you want and play symantics with ratios.Chester said:Look if you only think the ratio of "rotational weight" on a wheel is only 1.01 to 1 compared to other weight (frame, camel back, etc) then we are talking about nothing.
Try to pay attention. I said that it "definitely has an effect", but the effect is smalltlg said:Absolutely not. You said "Rotational weight is no different than normal weight". If it's no different, then it's no different. You wouldn't notice it whether it was 5oz or 100oz.
So now, obviously it IS different.
Yes, try and pay attention. Message boards have numerous topics and threads. You jumped into a different thread. Sorry, you didn't say "Rotational weight is no different than normal weight". But my response (which you jumped into) was regarding that. NOT the original post.Blue Shorts said:Try to pay attention. I said that it "definitely has an effect", but the effect is small
If the effect (try to follow me here) in the REAL world is negligible, then who the heck cares? ....besides you, that is.tlg said:My position was simple. Rotational weight is different than normal weight. You can argue all you want and play symantics with ratios.
If you've got test data on ratios, let me see, then perhaps we can have a discussion.
As usual most people who discuss don't really have more than a vague idea about the ratio.tlg said:My position was simple. Rotational weight is different than normal weight. You can argue all you want and play symantics with ratios.
