1 - 10 of 10 Posts
Banned
My rear tire wears out faster than my front. I've thought about swapping them to extend the life. Is this something others do or should I quite trying to be a cheap bastard and just run as is until the rear wears out and then buy a new one.
The wear is usually caused by climbing. Do like I do, and just walk up the hills. (At least that is the excuse I usually give when I walk. "Sorry guys, trying to save my rear tire.")
Kathleen in AZ
You don't have to put on two new tires at a time so I'm not sure what the fuss is about. Instead of switching, just replace the rear when it's done - less work and less $$ spent when you go to buy a new tire if you only have to buy one at a time. I generally go thru about two rear tires for every front tire. I also always figured the rapid wear on the rear tire was due to climbing - more weight and abuse on the back tire when grinding up our rocky hills.
livin' the dream......
Curious how many miles people are getting out of thier tires? I have about 400 miles on the tires I run now (Panaracer XC Fire Pro's) and have had them on for a year. About 98% of the miles were put on riding our trails around the Valley.
Is this low, high or average miles to get from tires?
Banned
If the tread is worn directionally, then just flip the tire. Some people are so slow that it really doesn't matter anyway. If it's a training tire then it really doesn't matter. If you're racing, then you probably wouldn't want to rotate a worn tire anyway. Be a cheap bastard!!! Get as much out of those industry overpriced tires as you can.
I bet 95% of riders wouldn't know if you put a directional tire backwards if they didn't notice.
rotate your tires
Same thing happens to my tires. I 'rotate' the rear to front and keep riding until both tires are bald (using Continental Verticals on front/rear). I'm pretty good about NOT locking up the rear tire (that tears up the trail). I think the reason the rear wears faster is because most of my weight is on the rear tire. And while climbing my rear tire DOES slip a lot more than my front tire.
1 - 10 of 10 Posts
