I hang my CX bike by a hook on the wall in my (very hot) garage. The front tire (Schwalve G One 38mm, tubeless on an Arch EX rim) went flat and I left it up there like that for a few weeks. When I went to reinflate, the tire blew off the rim at 30 psi. I tested it a few times by rotating the tire on the rim and the tire blows off the rim in the same spot on the tire every time. I think the tire is blowing off in the same spot where it was compressed against the wall with the hook. I took the tire off and replaced it with a 35mm Gravelking SK, which is holding just fine now.
I had a flat on the rear tire- 32mm Gravelkings SK, that also sat with a flat leaned I to the wall for a week or two. (I usually only ride this CX bike on roads and bike paths when the trails are muddy and the mtb is no fun.) I put a tube in it and pumped it up and now it has a sideways warp in it. I rotated the tire around the rim and the wrap is on the same spot on the tire. It's fully seated all the way around the rim. I think this is also the same spot where the flat tire was compressed against the wall.
Is this common- for a tire to become irreparably warped from going flat and sitting in a compressed state for some time? Can I nurse these tires back to health, I should I make a belt out ofnthem?? Did I overlook something? Both of these tires have plenty of tread and should be good for hundreds more miles.
