1 - 6 of 6 Posts
Over 200lb racers running 2.35 vs 2.5 ??? Smaller tire offers lower rolling resistance...bigger tire has larger footprint creating better traction and smoother at low pressure over small bumps. Is a bigger tire faster and better control for bigger rider? Let's hear your thoughts...Pro's & Con's. Thanks feller's.
Glad to Be Alive
I weigh 210 with armour and back pack about 220-225lbs. I run michelin 2.8's front and back. When racing I go to highRollers 2.5. I can feel them slipping a lot though.
Bottom Line: Race with smaller tires but keep the big tires for every day riding.
Discussion Starter · #3 ·
Thats what I was thinking...at least a 2.5 for me (at 200lbs - no gear) for race. I'm actually glad you replied cause I got a question about running UST and I know you swear by 'em. Wouldn't a tubeless set up be more vulnerable on rockier courses (to cut for example) which would make fixing a flat with a tube easier? On the other hand not having a tube saves weight to allow for a dual ply (which is less likely to get cut)...this is my dilemma. To tube or not to tube. lol Thanks bro
p.s. Can you notice a significant difference between Super Tacky and Slow Reezay?
- JJ
Chillin the Most
- JJ
FYI, Maxxis 2.5 tire = @ 2.35. ;)
1 - 6 of 6 Posts
