Greetings, fellow Intermountain folk. Though I've a question regarding choice of tires, I'm posting within the regional forum because I'm guessing the types and conditions of trails we ride are similar.
First, a little background info:
I ride a 2008 Raleigh hardtail that came with 26x2.25 Geax Saguaros, which I replaced in fall 2009 with 26x2.1 Panaracer FireXC Pros (cheaper 66 TPI version). The Panaracers have been very good to me but their knobs are wearing flat. It's time to replace them, so I thought I might check here to see what y'all would recommend.
Aside from reversing the tread rotation for the rear tire, I've never used an asymmetric setup (not sure what you call it--different front and rear tires), but that is something I'd be willing to consider.
Most of what I ride varies between hard pack, moondust, and loose gravel and rock. Other than the occasional crossing, I try to stay off the trails when they're wet, so mud grip and clearance are secondary concerns.
I also ride on asphalt, but that's out of necessity for errands and such, so I'm not overly concerned with noise or roll resistance.
I'm not a racer, and I descend a little faster than most of those with whom I ride but my climbing speed is average.
Basically, I mostly care about price, longevity, and traction climbing and descending these dry mountain trails we have here.
Based on this data, do y'all have any recommendations? Should I stick with the 66 TPI Panas or swap out a fatter tire for better rear traction? Are the 127 TPI Panas worth paying nearly twice as much?
Thanks in advance for any insight you might have.
Happy Trails,
-- HP
Happy Trails,
-- HP
