I recently switched to Panaracer Rampage 2.35s on the front and rear of my bike (Marin XC Quad), since they are highly regarded on this board, and the Nevegal on the front was washing out abruptly. This was with narrow (17mm) Mavic 223 rims. The cornering stability and even straight-line traction, particularly in the loose stuff, and most noticeably on the front, was much better. I'm 220lbs with gear and was running 40psi front/rear.
Well then, I switched to wider (26mm) Sun Singletrack rims (great buy at Jenson with XT hubs, btw), still with the Rampages. I've tried pressures from 35-50psi, but the front seems squirrely in the loose stuff, not very confidence inspiring at all. I understand the wider rim changed the footprint of the tire, but shouldn't traction be improved?? Should I try running even lower pressures even at my weight? What pressures are other heavier riders running with the Rampage on the front? The rear is working great with 40psi.
