I was just wondering what you guys run for tire pressure?
Yeah, what he said. I've just been going by feel on my presta-equiped bike.rdickens48 said:is there a guage that works with the presta valves?
Am I the only one that rides with high pressure in their tires. I run 50 PSI in my Cinder 2.25s. My twisted logic for this would be 1) less chance for pinch flats, 2) less chance for rim damage when hitting hard obstacles such as rocks, 3) let my suspension compensate for the higher pressure.rdickens48 said:I was just wondering what you guys run for tire pressure?
Lower pressure (within reason) will provide better traction than higher pressure. Think cornering. With higher pressure, your tire's tread will break loose sooner than the side wall. With lower pressure, your tire's sidewall will give more before your tread does. You'll be less likely to slide out in the corners.Call_me_Clyde said:Am I the only one that rides with high pressure in their tires. I run 50 PSI in my Cinder 2.25s. My twisted logic for this would be 1) less chance for pinch flats, 2) less chance for rim damage when hitting hard obstacles such as rocks, 3) let my suspension compensate for the higher pressure.
If someone wants to help me to understand what I might be missing by not lowering the pressure, I'm all ears.
Bob
Now see, that's the difference, I really love pinch flats.azdrawdy said:Been running 48 psi in my IRC Mythos XC 2.1 for several years now. I don't like pinch flats and really don't like the squirrely feeling I get when the psi drops below 40 psi.
Michael
I knew there might be an issue with washout on cornering, but I guess it's not much of an issue cus I'm such a slowpoke.Ken in KC said:Lower pressure (within reason) will provide better traction than higher pressure. Think cornering. With higher pressure, your tire's tread will break loose sooner than the side wall. With lower pressure, your tire's sidewall will give more before your tread does. You'll be less likely to slide out in the corners.
The same principal applies to riding over rocks, logs, etc.
One of the biggest differences in traction with lower pressure is in wet and muddy conditions. If you are running tubes, you shouldn't go much below about 38 PSI in the rear and a pound or so less in front. If you go much lower than that, you will be risking pinch flats. If you want to enjoy an insanely great ride, go tubeless and drop down to 28-30 PSI. Then you'll really know what traction is.Call_me_Clyde said:I knew there might be an issue with washout on cornering, but I guess it's not much of an issue cus I'm such a slowpoke.I never did equate lower pressure to better traction over obstacles. I'll have to lower the pressure and experiment a bit.
There are too many generalities in your statement to even begin to respond. I run below 38 psi on both my tires. I haven't pinch flatted in about 3 years. All of this without the "benefit" of tubeless tires.BrandonJ said:One of the biggest differences in traction with lower pressure is in wet and muddy conditions. If you are running tubes, you shouldn't go much below about 38 PSI in the rear and a pound or so less in front. If you go much lower than that, you will be risking pinch flats. If you want to enjoy an insanely great ride, go tubeless and drop down to 28-30 PSI. Then you'll really know what traction is.
for presta valves specifically. Of course I guess I've never really looked for one. One does not look for what one doesn't need. I've always had a floor pump with a gauge and never really needed anything else. I've used the adaptors for years if I only needed to just check tire pressure. But 99% of the time when I need a guage it's because I'm adding air anyway. I probably won't ever get a presta guage, just don't need it, but it's good to know that they are out there! You learn something new every day. Thanks.ken50397 said:I have a Presta gauge that I have had for several years originally bought for my road bike. Presta has been around for a very long time, so I don't know why the trouble with a guage. Here is one I found in about 20 seconds. I am saying it is any good, but... http://www.jensonusa.com/store/product/PU703B00-Topeak+Smarthead+Digital+Psi+Gauge.aspx
I have not used in it a while since I bought a pump with it on it.
Ken.
