greetings
apologies in advance for the following wall o text & if this is redundant of another thread, but I couldn't find anything specific enough so here goes:
I'm 6'2" & 225Lbs & I ride a year old Transition Bandit 27.5 full suspension on my local trail (Sandy Ridge in Oregon - woot!) I like to catch air here and there & go as fast around bermed corners as by cojones will allow.
I recently invested in a fancy new rear wheel in order to go tubeless - I went with a Stan's Flow EX & have a brand new Conti Trail King 2.2 & I'm 99.9 % sure it has the Apex sidewalls.
First: I've had trouble getting it to seal. Put in at least 3 small bottles of Stan's sealant & it still would lose all air by the next day. The shop that helped set it up is at a loss & have even re taped and put in new valve to make sure, but nope - still won't hold air even overnight. Is this normal?
Second: On the final tubeless ride, the rear tire felt like it 'folded' during hard cornering & aggressive "dips" (g-outs?) several times. I've read about tubeless tires 'burping' but that is always described as sealant spewing out at the 'burp' spot. There was never any visible sealant leak. After this ride is when the above mentioned seal problem got so bad it wouldn't hold air over night.
Now I notice a significant wobble in the rear wheel like the wheel is out of true - but when I do my very scientific measurement (hold my finger next to the rim as it spins) I don't notice the rim being out of true... which makes me think the tire is actually warped now from the "folding".
I always run my tires well above 30 psi & have been trying to bring that down to enjoy the added traction. The traction is amazing... until the folding makes me all skitterish & now seems to have left me with a deformed tire.
I want to embrace tubeless. I really do. Are there better tires for larger fellows? Is the Conti fine, but just through my own fault of lowering the tire pressure too much, no tire could survive my girth?
cheers
cheers
