I've been running CushCore front and rear and am quite happy with them. First, the weight. They weigh the same as an inner tube, so it's as if I was still running with tubes weight wise. I've only run them in Michelin Wild AM 29x2.35 tires, which are lighter/softer than some other tires, certainly compared to DH tires. With the Michelins; tubeless I had to run around 25psi to prevent squirming and burping under hard cornering. With the CushCore I am running as low as 18-19psi Fr/Rr and still have great stability and feel. They will squirm a little or burp some if you're getting rowdy at those pressures, but just a little. The front end is much more supple and controlled over high speed chatter too, making it easier to maintain your line. Also, I'm yet to destroy a wheel or snakebite a tire since adding them, despite destroying 4 tires and 1 rim here in SoCal before adding them.
