Hi,
I need a set of tires that will reduce my total outside diameter (with the tire mounted) by about 6-8 mm. I am running into some clearance issues on a parts bin build. I'm not concerned with the width, I have clearance for about 55mm, but I can't seem to find any way to compare the distance between the top edge of the rim and the center tread.
(Is tire height the correct term?)
The bike will be ridden mostly on dirt and gravel roads, so tread does not need to be too aggressive, and it has a Headshok, so super cushy, high volume tires are not necessary.
First post , so please excuse any inadvertent newbie mistakes.
Thanks,
T
Thanks,
T
