Question: do any of the following tires fit into a 2019 yari 27.5+/29er fork?
if you have the following tires, do you have a diameter and what fork are you running? Thanks
xr4 29 x 3.0
dhf / dhr 29 x 3.0
rekon 29 x 2.8
vigilante 29 x 2.8 is 768mm
Purgatory 27.5 x 3.0 is 730mm
2019 yari fork :
measurements put the axle to bottom of the crown at 393mm ish.
393 - (730/2) = 28mm which is about what i get after trimming a 1" spacer to test clearance to the purgatory at full compression.
FWIW:
bikecalc lists a 29 x 3.0 at 774mm in generic terms.
393 - 6mm clearance = 387mm * 2 = 774
so 774 might work on this fork.
xr4 29 x 3.0
dhf / dhr 29 x 3.0
rekon 29 x 2.8
2019 yari fork :
FWIW:
