This is for tubes (I dont like tubeless and wont consider it, BTDT)
I've had this happen many times, 1x this weekend with nevegal and mavic 823 (yup running tubes on it)
700c rims, mtn rims, different tires
Tire is either not centered and hops or blows off the rim and explodes the tube and sometimes even stretches or rips the tire
It's not always where the valve stem is either and for a variety of tube and tire sizes
I do run higher than normal pressure most of the time, but this even happens with normal pressures
Are there any tips for on the trail as well as will full tools to seat tires properly?
I try eyeballing, pushing the bead in on the high spots, adjusting with tire levers
Inflate a little, ride, inflate more, ride
I know that sometimes beads (wire or kevlar) are not perfect
Some people mentioned soapy water, soap, wax, silicone oil or grease (but I think that's mainly for tubeless and/or difficult to mount tire/rim combos and talc in the tube
I also know that rim strips and tire tape can interfere
For the latest one, I think Im going to put the wheel in a truing stand to "true" the tire
G
PS I already search this sub forum for tire seat and skimmed about 100 threads, which were mostly for tubeless
G
