I bought this and work perfectlyfrozen said:I am looking for something small, waterproof.:cryin:
Hi, what housing are you use?? it is very small...frozen said:Thanks
These are nice, maybe. Problem is that I have just 35 mm to mount switch and waterproof connector, both have to be max 15 mm deep in housing :madman:
Space! :madman:brum said:If you have the space I can recommend the Schurter foil switches, they are 'normal' size at 15mm or so diameter. But far more reliable and nicer to use compared to mechanical switches.
broken linkfrozen said:Space! :madman:
I found this:
http://export.farnell.com/apem/ipr3sad6101/switch-spno-chrom-red-btn/dp/1082448
nope... not here in the UK...frozen said:link works if you have already opened farnell export page - http://export.farnell.com/
That converts to $35 au.... ouch! That is worth more than my carfrozen said:APEM - IPR3SAD6101 - SWITCH, SPNO, CHROM/RED BTN
Manufacturer: APEM
Order Code: 1082448
Manufacturer Part Number: IPR3SAD6101
Unit Price: £8.97
