bigb73 said:
I had a 550 lb steel spring so I went with a 550lb Ti spring. Seems a little on the stiff side. I would like to try a Ti, 500 lb spring. Does the Ti run a little on the stiff side?
Most steel springs are made to 10-15% tolerances, on a 500 lbs spring that could be plus or minus 50 lbs. The Ti spring was probably closer to its listed rating, which is why it feels different.
A 550 lbs spring takes 550 lbs to compress it 1 inch regardless of what it is made of, unless it was made with loose tolerances and is not actually a 550 lbs spring.
I had my springs tested, the 300 fox steel was 285, the 350 fox steel was 370 and my 300 (don't remember brand) Ti spring was 290. Almost a 30% difference in spring weight between the fox steel springs, its no wonder i thought one was too soft, and one too hard. I ended up buying a 325 Ti spring, which is actually a 326.
