What is the difference between thru-axle and bolt-on axle?
How hard is it to change from a thru-axle to a bolt-on axle?
Also maybe someone has pictures of both, maybe that will help me understand better.
THANKS!!!!!
I found this but still can't get it. So does this mean if the back wheel comes with a thru-axle, that I will have to change it to a bolt-on axle? (wheel is going on a riot)I believe that a thru-axle actually attaches is held in place by the frame itself rather than a nut on the other side the squeezes everything together like a quick release. This means that a frame has to be designed for a thru-axle (e.g. Maxle), whereas a thru-bolt would just use standard dropouts
THANKS!!!!!
