1 - 6 of 6 Posts
I guess you're right. It says "topcaps"but is referring to the bolts on top of the fork legs not the topcap on the stem. I've always done snug enough that the headset doesn't knock.
ParkTool Procedure
1. Remove bolt and top cap to inspect steering column. Lubricate adjusting bolt and re-install cap and bolt by hand only. DO NOT TIGHTEN.
2. Loosen stem bolt(s) that secure stem to the steering column. Lubricate these bolts if they are dry. NOTE: DO NOT LUBRICATE INSIDE STEM OR ON STEERING COLUMN SURFACE.
3. Wiggle the stem side to side to see that it is loose. If the stem is jammed or rusted frozen to the steering column, no adjustment can be made.
4. Align stem straight to wheel and gently secure the top bolt. Stop when any resistance is felt.
5. Tighten stem bolt(s).
6. Check for play by pulling back and forth on fork. Turn the handlebars in different directions while checking for play. There may be play at this early setting. Use care when grabbing suspension forks, because the legs may have play. Grab upper portion of fork.
7. To adjust bearings, LOOSEN STEM BOLT(S).
8. Turn adjusting bolt in center cap only 1/8th turn clockwise.
9. Secure stem bolts, check for play again.
10. Repeat adjustments as above until play disappears. Remember to loosen stem bolts before turning adjusting bolt in cap.
11. Check alignment of stem and tighten stem binder bolts fully.
1 - 6 of 6 Posts
