1 - 13 of 13 Posts
Thanks for the reply. How do you find the TwinLoc system?
The TwinLoc is two stage and easy to use, What I appreciate the most is being able to unlock suspension quickly without taking your hand off handlebar when there's a sudden change in terrain, or if you've got a
bit of speed up.......not so important if you know the trail well.
Discussion Starter · #7 ·
The TwinLoc is one of the reasons I like this bike, what does your bike weigh?
Heavy bike. I've replaced the handlebars and wheels, knocked quite a bit off. I use the twinlock a lot more than I thought I would. Next thing to go is that DT Swiss POS rear shock. I flipped my frame chip over and raised the BB, and I like the handling a lot better.
Discussion Starter · #11 ·
My 740 weighs 14.5 kg - about 32lb, I've made no changes other than tyres which are Hans Dampf .
Interesting, according to the Scott website the 2014 Genius 740 weighs 28.6 lbs. at 32 that does seem a bit heavy for a trail bike.
I think it could be the weight of the small frame mine is the large also they may not include the pedals, mine weigh 404 grams for the pair the bike came with the Nobby Nics which weigh 580grams each my Hans Dampfs weigh 765 grams each which makes the total = 774grams or 1.7lb that brings the 28.6 lbs up to 30.3 lbs and doesn't include the bigger frame I don't know the weight difference.
I find the ride is great, I ride mountain trails with a lot of sharp edged rock and I find it heaps easier to ride than my older 26 specialized fsr
1 - 13 of 13 Posts
