09 vs 10 stumpjumper comp...
Hey im in the same predicament atm, however as i missed the early specials im unable to find an 09 in med here in Aus
Im also weighing up either a 10 Giant trance X2 and 10 Trek Fuel EX8 which are similar in price and build spec (the stumpjumper however gets full lockout in the rear shock).
In terms of components specs between the 09 and 10 models it's pretty much the same, the only main difference between the 2 model is the 10 gets an extra 10mm in suspension travel to 130mm vs the 09 models which has 120mm, aside from that its pretty much identical, same fork, same Triad shock, brakes, cockpit components and even tires.
In terms of modifications in my opinion probably seats and tires, you didn't mention the price the 09 is for however based on the above i would personally go for the 09 if it is indeed in good condition.
Just a side note man i wished i lived in the US, the 10 comp rrp in US is $2200, in AUS land the rrp for the same bike after rate exchange is over US $3500!!! :eekster:
So whatever price/bike you end up with just thank god you don't live in the over taxed land known as Australia!
