For XC riding, the choice of a stem does not typically involve strength. It's usually just looks and weight.ohvina said:The easton's is 40% less in price.
What will u choose?
Funnily enough, I have bent one, destroyed the fork at the same time, but the stem definitely bent.toyota kawasaki said:but its a stem.. how many people have broken a stem?
First off most any stem will get the job done, the exception are the stupid light roadie weight stems that even the roadies break but they are made purely for racing or weight weinies and not meant to last more than one season.ohvina said:The easton's is 40% less in price.
What will u choose?
I'm not sure which Easton Stem you are referring to. I know it's the EA 50....but which year? Is it on closeout?ohvina said:To me, factors including strength, durability, weight and cost are more significant than just the "look".
Comparing the easton and thomson stem,
Easton: lighter, cheaper, traditional clamp on steer tube, but 2-bolt clamp on handlebar
Thomson: look, beautiful machining, 4-bolt clamp on handlebar but innovative clamp on steer tube
Is there any singificant difference in respect of strength and durablity?
What size are you trying to get? I have a new Race Face Prodigy 120mm that I would be willing to sell for real cheap.ohvina said:The easton's is 40% less in price.
What will u choose?
On a 2 bolt handlebar binder the bolts are torqued 175-250 inch/pounds a four-bolt thomson only 48 i/p2-bolt vs 4-bolt is just preference. I ride with both and don't care which I use. In fact, 2-bolt hb clamps are recommended for carbon bars.
On a pinch type 2 bolt steerer tube binder the torque is 100-150 i/p a thomson is 48 i/p. Without a torque wrench overtightening is easy leading to carbon and al handlebar and steerer tube failure.In fact, when it comes to clamp strength....Chris King headsets do NOT recommend using stems with the Thomson-style clamp. They recommend the standard 2-bolt wrap around clamp..found on most stems.
WG has hit the "stem" on the head as it were. This is the reason I would spend the extra cash for the Thomson stem, I too have hit my knee on the bolts of normal stems and it hurts like hell and makes the price diff well worth it to me.wg said:I went with Thompson because of quality and the lack of protruding bolts. I've smacked my knee a few times on other stems' bolts and the small price diff to go up to a Thompson was worth it to me. Its a set it and forget it component. Not something you ever want to worry about. Bikeman has them for about $65.
Others, including Bontrager make stems with recessed bolts.LyNx said:WG has hit the "stem" on the head as it were. This is the reason I would spend the extra cash for the Thomson stem, I too have hit my knee on the bolts of normal stems and it hurts like hell and makes the price diff well worth it to me.
would you care to elaborate on that point?Blue Shorts said:I've had issues with Thomson stems (most people don't, btw).
The specs vary by manufacturer. Race face recommends 65 in-lbs per bolt (2-bolt steerer clamp) Where the heck did you find that 175 - 250 number? It's bogus.vermont said:On a 2 bolt handlebar binder the bolts are torqued 175-250 inch/pounds a four-bolt thomson only 48 i/p.
It's far easier to over-torque a Thomson handlebar clamp thahn it is to over torque a 2-bolt handlebar clamp. WIth 4 bolts, half the torque/ bolt will apply the same force as a 2-bolt clamp with twice the torque.vermont said:On a pinch type 2 bolt steerer tube binder the torque is 100-150 i/p a thomson is 48 i/p. Without a torque wrench overtightening is easy leading to carbon and al handlebar and steerer tube failure.
I have seen plenty of pictures of broken stems and to me it looks like it could only take one to ruin your day.
from the park.com torque guideBlue Shorts said:The specs vary by manufacturer. Race face recommends 65 in-lbs per bolt (2-bolt steerer clamp) Where the heck did you find that 175 - 250 number? It's bogus.
i am agreeing with you that it is easier to overtorque a 4-bolt and a thomson style steerer clamp.Blue Shorts said:It's far easier to over-torque a Thomson handlebar clamp thahn it is to over torque a 2-bolt handlebar clamp. WIth 4 bolts, half the torque/ bolt will apply the same force as a 2-bolt clamp with twice the torque.
The Thomson steerer clamp has a smaller contact area than a pinch type clamp. It takes less force to damage the steerer.
You appear to have it all backwards. I's easier to damage a steerer with the Thomson clamp...and easier to damage bars with a 4-bolt handlebar clamp as compared to a 2-bolt clamp.
Do you make this stuff up?
