I have had this creaking/movement on the headset area for couple of years and seemed to have finally figured out the cause but now I am looking for a solution. I have a Thomson stem mated with Chris King headset on Intense Tracer. I have this annoying creak/movement on the headset area when ever I apply the front brake hard or intentionally do an "endow". After doing many experiment with LBS, it was determined that the creaking/movement is coming from Thomson stem with help from CK techsupport also. Apparently it's due to how Thomson stem clamps onto fork steer tube. Because it clamps on the back of steer tube like a "clam shell" with two bolts, the contact area to steer tube is a lot less than other brand stems that warp around the fork steer tube completely; hence, causing movement between steer tube/stem area. According to CK tech support (he seem to be well aware this issue w/ Thomson stem), I need use different brand stem all together or keep retightening the stem via trial error until I get it just right. However, that requires holding the steer tube perfectly perpendicular while tightening the Thomson clamp's two bolts. I find this task to be impossible as no matter what I do the creaking noise is heard and felt every time the two clamping bolts are tightened alternately via small turn. Of course if I do an "endow" test afterward, creak/movement is felt and heard ever louder and clear. I am sure someone else had this issue with Thomson stem perhaps would like to share a solution if there's any. I would hate to discard the stem since it's a very nice one, albeit it has creaking issue. It could just be this particular Thomson stem too as I have another shorter & newer Thomson stem that's on DH bike and has no creaking issue at all...yet. Thx for any inputs!
STH
STH
