I have a 2001 Trek 6700. How do I figure out which size and weight to choose? Thanks.
http://www.lhthomson.com/elite_sizes.asp
kdiddy said:The diameter should be stamped right on there, typically below the minimum insertion line. I'm assuming that by weight, you actually mean length. Is your current post too short? Too long? MTB posts are typically 330 to 400 mm long, but again, I would measure your existing seatpost and go from there. If you find that you have a lot more post inserted into your seat tube than is necessary (you have it inserted well below the minimum insertion line), you could buy a post that is that much shorter than your current one.
thanks kdiddy. i went to a LBS and got measured. they adjusted the height of the handle bar and recommended a 30mm setback seatpost. what brand makes a 30mm setback seatpost.kdiddy said:...This is all stuff your LBS should have done when you bought the bike...
did you mean, like swapping stems? i'm not sure if they'll do that since i didn't buy the bike from them. they did suggest changing the stem but decided to see how adjusting the spacers would work for now.kylejohn4543 said:They didnt just replace your stem? They should be able to do that.
