New post, even Tim didn't notice this in the other thread.
http://forums.mtbr.com/showpost.php?p=2051197&postcount=47
I did.pacman said:New post, even Tim didn't notice this in the other thread.
Its primary use is as a shock to damp sudden turns of the bar either from the ground/obstacles or the rider. The quicker the turn the bigger the resistance. The design is such that it always takes zero force to re-center the bar.one1spede said:I'm curious too. I had read some threads about this and looked into purchasing one, but I can't figure out how they actually effect your steering. It seems it may just help recenter your bars/stem/front wheel, but how does it effect turning? Any thoughts would be appreciated, still trying to understand this. Thx!
I would figure it varies the resistance when you steer, so that the further your handlebars are from straight, the less resistance there is. When the handlebars are straight ahead, there will be the greatest resistance to turning. There is something similar with computer joysticks: you can set an acceleration curve. So you don't have a linear acceleration curve, the further the joystick is from center the more effect your movement has. This enables you to have more authority the further your joystick is from the center. I have a big problem controlling my front wheel when I am biking, especially when I am tired. This should be a very useful gizmo.one1spede said:I'm curious too. I had read some threads about this and looked into purchasing one, but I can't figure out how they actually effect your steering. It seems it may just help recenter your bars/stem/front wheel, but how does it effect turning? Any thoughts would be appreciated, still trying to understand this. Thx!
