1 - 6 of 6 Posts
· Registered
I am 5'10"ish have about a 30" inseam and have the possibility to buy a Kona Kahuna online, so I wouldn't get a chance to try it out. Would a 16" frame be too small, I've never gotten on a bike that small. If so what problems would I run into and could they be fixed?
· Premium Member
Compare the ETT lengths and seat tube angles of this and your current bike. The seat tube length does not matter. I am just under 6'1", 35" inseam, and have fit on production frames from 17" to 20"
· Registered
Discussion Starter · #5 ·
Currently I'm riding a 20" Raleigh Mojave 2.0 and its a little big. The standover height is a little much, its TT is 578mm, the seat angle is 73, and a standover height of 794. The 16" Kona Kahuna has a TT of 572, the seat angle is 74, and the standover height is 773. I'm not an expert but that doesn't sound too bad.
· Premium Member
Pretty close. The steeper STA on the Kona will actually make the reach a bit longer than your current bike if you use the same length stem and same bar.
The Kona should be OK for you with the usual fitting tweaks.
1 - 6 of 6 Posts
