I was up at Whistler yesterday putting my 7point7 through it's paces. It took me a while to get used to the bike on the A-line jumps but after 3 runs I was hitting all the jumps with confidence. The bike rips, the forks could be a little plusher, but the back end for me was more than good enough, the only time I felt it was getting overwhelmed was doing Hornet into lower a-line at Mach 4, but then again what wouldn't have a hard time with those bumps, :eekster:
Anyway my only beef was with the tires/wheels.
Firstly the tires: now the theory behind tubless is running lower pressures as there's no tube to worry about pinching. This means that the sidewalls can be more supple too. Now the Highrollers fitted to the 7.7 as standard are good for riding the shore and grip great in that situation, however once the speed picks up they don't work so well.. the lack of stiff sidewall means that the tire rolls over more when giving it some stick in the corners. At more than one point yesterday I burped the tires pretty good and did it so bad one run that I had to stop to add pressure. I had to really up the pressure in the tire to stop it doing this and that kind of negates the advantage of tubeless. Are other UST tires better for this? Michelins? I'm a hard heavy rider and so I'm sure I give the tires a harder time, I like UST so far apart from this problem and don't want to have to resort to tubes again to get tires that have that stiffer sidewall... any suggestions?
Secondly the wheels, specifically the rims. The 823 rims are working out fine so far, but yesterday I lost spoke tension and found out that it's the screw-in spoke supports that were coming loose. Anyone else seen this? Looks like I'll be going at them with the locktite, but still, it's not a great scenario. Thankfully I was able to fix it on the hill and tweak the wheels true again.
Other than that a great day in Whistler with the bike inspiring me to rip it up. What more can you ask?
