I've had some Louise BAT brakes for a little while now. The BAT system allows you to adjust the lever engagement point independently from the lever reach, similar to the system on the Juicys. It works very well indeed. Folks sometimes ask how to remove their Magura Louise levers, so in addition to showing the guts of the Magura BAT system, you can also use this as an explanation for disassembling any Louise and Louise FR lever. The BAT lever carrier is the same as the old, non-BAT carrier. They are interchangeable as far as I can tell.
Here is what the lever looks like installed. The BAT is the red knob, and the hole to the left of it is where you insert the allen to ajust the lever reach.
NOTE: if you don't have a BAT lever system (pre-07 Louise), skip the next paragraph. Also, it is not necessary to take the steps in the following paragraph even if you DO have BAT. It just gets some of the parts out of the way and shows you the bits...
(Optional steps) First off, it helps to gently pull the red BAT knob off the post it on. It is not threaded on there or anything, just held in place by friction. A little rocking while pulling will get it out. Next pry the black rubber gasket off the lever. It is also held in place by friction where it is shoved into the holes in the lever.
Use a 2.5mm allen to back the reach adjust screw ALL the way out (counterclockwise). You will feel some resistance about halfway out. That is normal as the bolt head needs to climb out of a snug well. In this pic you can see the reach adjuster screw ready to come out of the lever and the naked threaded post where the BAT knob was:
On the underside of the lever is a hole (green arrow) that the plastic lever carrier has a tooth that snaps into. This is what holds the carrier in the master cyclinder. Use your 2.5mm allen to gently push against the plastic tooth in the hole and then push the whole lever and carrier towards the centerline of the bike (red arrow):
If you have depressed the tooth enough, and have backed the reach adjuster bolt out far enough, the lever and carrier should slide pretty easily:
Now you can pry the carrier open and remove the lever from it. You need to spread it just enough that the two shafts come clear of the channels they move in:
You can now push the black plastic shaft out of the lever body (shown on the right). The plastic shaft is part of the reach adjustment system and has a "front" and "back". The reach adjuster bolt passes through this shaft and the wider opening needs to face forward upon reassembly to receive the reach adjuster bolt's head. In this pic I spun the black shaft around backwards so you can see the large recess the bolt head nests in.
The silver metal shaft is held in place by leaf-spring tension from the BAT system. It also slides out like the black part, but it takes a bit more force becase the leaf spring makes it want to go cock-eyed once one end pops free.
Here you can see the shaft removed and the leaf spring relaxed:
A 2.5mm allen will back the BAT bolt out of the lever:
Finally an exploded view of all the parts. Assembly is the reverse process.
