1 - 20 of 27 Posts
The Enduro SL struggled a little over xmas in the mud. The sub-zero temperatures froze the mud to the point where it couldn't shed it and both the front and rear wheels would not move.
Half my time on the ride was spent finding twiggs and digging the mud out so I could ride again :madman:
I've generally found the bike pretty good over this winter. Front clearance hasn't been a problem until now. The rear end gets clogged every ride around the front mech. In fairness, the rear of my old 04 enduro struggled on that section of the trails to the point where the wheel wouldn't move.
The Eskar tyres have been pretty good so far, but I have found their limit in the mud :D
Because of where I live I also get the full benefit of British mud every ride, mostly clay unless I get in the car, since I've switched to a wider tire (2.00 to 2.35) I have better grip in the mud and the new Maxxis Ignitors have a lower profile than the stock balloon tires on my Stumpy.
Here I am up Leith hill before the mud arrived and without my cycling gear, looking like a complete weirdo:D:
Different bike but the rear wheel on my Stumpy started doing that this first winter on the bike, only thing I could do was get lower profile, wider (was) 2.00 to (now) 2.35 tires which has fixed it so far:thumbsup:. It was taking deep scratches out the seat stay arch with those stupid Specialized Resolution balloon tires.
...idios...
It's easy to protect the underside or the fork arch, just tape it up...
Infrastructure Pipe Metal Iron Synthetic rubber
I use electricians tape because it's cheap, flexible, easy to remove and very durable. I ride a lot of gravel, so as well as inner tube protection for the chainstays, I carry the tape on as far up as possible to protect from flying trail. I also have this piece of plastic (cut from the packaging of the Specialized Enduro mud flap that protects my shock) which keeps spray and muck away from the chainring and BB pivot bearings, but also helps to feed mud straight down and away from the frame..
Spoke Metal Synthetic rubber Automotive engine part Bicycle accessory
I try to avoid riding in mud as much as possible, as much for the sake of the trail as for my bike, but as we all know, it's not always possible, especially here in the UK.
Yes, it is a niggle with the fork arch...
Yes, the triangular cut-outs formed in the front wheel fork arch often picks up & traps stones that are too large to again be released between tyre and the arch as the wheel continues to go round (or twigs similarly, for that matter).............Whilst not causing any real damage, it is an annoying re-occurrence, having to stop release debris, as it makes a loud rubbing noise on the knobbly tyre tread
For some reason, the front derailer on the SL seems particularly susceptible to catching mud, when compared to my previous bikes
...idios...
"What are those tire you have there with the interesting tread pattern?"
They're Continental Petrol 2.5's, my 'town' tyres. They roll very quickly on pavement and the high volume makes them excellent for urban shenanigans. They're actually pretty decent on the trails so long as it's dry and not too loose. The 2.1 version is called the Leader, or there's a 2.3 called the Flow. My partner has just ordered the 2.1's for her Stumpy, so we'll see how they perform over the next few weeks (if it stops snowing/raining!).
If you're running a front derailleur, that plastic fender on the inside of chainstays will also keep the majority of mud and muck from the spring/body area, as well as the BB and pivot bearings.
Helicopter Tape and inner tubes
Follow-up to SteveUK's advice;
For those that might not already be in the know; there is a guy on Ebay that sells Helicopter Tape in convenient widths & short lengths and at very cheap prices; the product is great
http://cgi.ebay.co.uk/1m-x-5cm-3M-H...ryZ22679QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Length-ways-slit old inner tubes, wound tightly around and tethered with plastic cable-ties on the likes of chain-stays etc, works really well too...........Not sexy looking, but really robust
The photo below shows my Ellsworth Joker employing an inner tube applied in the manner mentioned above to good effect, in order to protect an odd-shaped rear arm/otherwise hard to protect with off-the-shelf purpose made chain-stay protectors
Hmmmm Uk Mud!!
I did a loop around Cheddar Gorge on a 07 Stumpy before Christmas and the mud on one of the Bridleways (Read path across/up a field!!) was unreal. Impossible to ride and even pushing the bike the back wheel clogged up around the seat and chain stay pivots, having to stop every 100m or so just to free the back wheel to rotate. :madman: The clearance on the front fork was fine though. I'd had a set of tubeless Fast Trak Pro tyres, which are definitely the wrong tyres for the situation. Although I picked them up cheap at a close out.:thumbsup:
Bicycle tire Bicycle wheel rim Bicycle wheel Spoke Bicycle part
Bicycle accessory Tool Bicycle Pipe Synthetic rubber
EGF168 said:
That's exactly what mine looked like after every muddy ride until I got new low profile tires.
Happy mudding:thumbsup:.
The Fast Trak Tyres (26x2.0) are visually quite a bit smaller than the stock 26x2.0 resolutions that were on there despite being marked up as the same size. I've actually got a set of Conti 2.2 mountain kings Protection which were given to me as a Christmas present that are going on there next. So we'll see how they compare. I'm actually awaiting delivery of a compressor so I can try and mount them Tubeless :thumbsup: (Going tubeless was the best thing I ever did, haven't had a puncture since and have recently converted my older bike to Ghetto Tubeless) Nothing like trying to fix a puncture when the wheel is covered in mud and the temp is freezing!!;) :D
The problem as I see it is that you don't have enough wetness with your mud. In the Pacific NW, it's SO WET that the bike gets 'rinsed off' as you ride too. Maybe I'll post a pic of mine after next ride.
What you need are bontrager mud x tyres - they are a narrower profile and do not pick up as much mud, and they shed mud quickly - they're probably the best winter mud tyre. The resolution pros are pants in the mud.
Gticlay
You are quite right about the mud here being to sticky and not wet enough to just drop of, we get allot of clay in the UK.
nic92516
I don't know where in the UK you ride but if I tried tubeless tires I would get at least a puncture every other ride because of stupid Hawthorne hedges with huge 2 inch spikes,
Now I come to look closely your tires do look a bit smaller than my Resolution pro 2.0.
Tell us how the Mountain King 2.2 tires perform when you've tried them, I saw them on a Marin the other day and though they looked very interesting.:D
I have never tried the Spider tires but I have had a number of bad experiences with Hutchinson both were absolutely awful tires, I don't know if they have improved since I had the Scorpion tubeless and the Mosquito 2.3 but they were the worst tires ever.
I will of course be happy to try some if you send me a complementary set.:D
1 - 20 of 27 Posts
