In the spirit of Nurse Ben, I'm working on tinkering with my second Revved frame. I haven't been able to get the Shred Dogg to my liking, so I'm working on a short travel Megatrail build (not a fan of mullets and I like 27.5"). I have a "regular" full coil Megatrail (170mm front, 155mm/165mm rear), with some chunkier tires. Works great, but it's really exhausting on some XC style trails.
In order to accomplish shorter travel without messing with the geo I like, I'm opting to run a 29er fork with 150mm travel and 44 offset for the lighter bike. The AtoC on the fork is the same as the one on the "regular" megatrail (the tiger bike) with a 27.5 170mm travel fork (that has a 46 offset). I've also reduced the stroke on the rear shock to 230x60 instead of 230x65. Part of the reason I picked the Megatrail is it will clear a plus tire (2.8 officially), and I found it will clear my 3.0 studded N45th Warchilds.
I have no idea if this is going to work, so here's hoping. Otherwise, it's back to experimenting.
Eventual final build:
Megatrail size 2 long, tall headset cup
Ohlins 29 150mm RXF36 m2 with 44 offset
Ohlins TTX air rear 230x60
XT 12 speed drivetrain
Hope Mono brakes (waiting on the replacement cable for these)
35mm Spank stem, 800mm Spank vibracore bars
Transfer 150mm post
Canfield bros 160mm cranks with 32t chainring
Wheels: M542 rims, hope hubs with Aggassai front 2.6 and Forekaster rear 2.6 (most likely will change this, but it's what I had lying around.. I also have a set of studded tires to ride this in the hero snow for the spring)
Currently running (until everything comes in)
30t chainring
Fox 36 RC4 27.5 with 170mm travel
Bike Yoke 160mm post
Shimano Zee brakes
When for a test ride this morning. I have the suspension tuned firm (the way I like), but I didn't like the feel of the fork in the front. It felt almost like I'm running a mullet. Going to try reducing the air in the fork next time to see if that helps. With the shorter rear shock. the bike tends to be more poppy and definitely turns a bit faster.
Positives: Love the feel of this ride. Feels like a race car (you can tell the difference in the progressiveness of the air vs the coil) compared to my tiger megatrail (full strength and full coil), which is going to plow over everything. Doesn't feel like overkill on the longer XC rides.
Negatives: Not enjoying the Fox 36 after being on an Ohlins the past 6 months. Also, it feels very odd with 170mm in the front for now and 142mm in the back. I'm not enjoying the Zee brakes, but they work. I'm also hating the 30t chainring, because it feels like I'm constantly spinning and cannot get enough torque to really feel like I'm going somewhere. Still not a fan of the post because it feels like it loses air during the ride, and it makes the bike feel really choppered.
Next steps: get the new fork on next week and the 32t chainring and see if that feels better balanced with the travel and better torque.
Transfer 150mm post
30t chainring
Shimano Zee brakes
