....here are some preliminary findings on the Fox DHX 5.0....
First the "GOOD":
this shock feels very, very good! Just did a short 1 hour ride on my usual local XC (steep, rooty, rocky, twisty- ST).....it was funny at first, similar to the "brain" shock, my pro-pedal adjustment did nothing & was bobbin' like a mutha in granny! Somewhere in the middle of the ride it kicked in & never had another issue. It really reduces pedal input resonance to nill. Also, it doesn't feel "dead" like the 5th Element. Very lively like the RC for J-hops & such...while the rear still sticks (tracks) very nicely. I definitely could feel a good bit of difference from the Romic. Very plush on the small stuff & incredibly Firm under pedalling power.
the "BAD":
there was no manual included with the shock & it was my impression that there are none available yet.....gonna call Fox tech in 5 min.
the "UGLY":
OK, here's where things get dirty. Coil removed....full compression of shock & there is definite contact with down tube (enough to gouge the powder coat) with the volume adjuster (bottom out) full out. Adjuster half way in/ out allows for ~1mm of clearance. Granted, this is with foam bumper fully compressed & last night (with coil installed) I could not get it to touch by jumping up & down attempting to bottom it with my weight ( I can usually do this on all my bikes). I actually prefer the feel with the adjuster set @ half way so no real biggie.....however, it is still a bummer to have to deal with the situation all together ( I mean, you ultimately want a perfect fit).
.........more thoughts as I get more time. It seems to keep getting better as the break-in period progresses.......
.....also, the 500# spring feels good (I need a 600# on a regular RC setup) w/ 150 PSI.....still need to get Fox's recommendation for Psi
First the "GOOD":
the "BAD":
the "UGLY":
