Said slacker, updated cabling routing, something upgraded about the pivot linkage bolt or bearing size (not sure).This I would like to know more about!
157 rear hub :madman:Said slacker, updated cabling routing, something upgraded about the pivot linkage bolt or bearing size (not sure).
157mm on rear hub (so, more expensive for frame swapping if a near wheel is required). Would imagine seat tube could be slightly shorter.
Geo chart link was dead.
Get a Works Components angle headset and this:157 rear hub :madman:
Would like to se geo like Wreckoning but with 145-150mm rear wheel travel. And shorter seat tube so I can run a long travel dropper even with my short legs. Maybe just maybe it might be a possible contender for a new bike.
Cascade link was designed for the current Offering. Do we know if it works with the v2?Get a Works Components angle headset and this:
https://cascadecomponents.bike/products/evil-offering-link
For $350 you'll have a mini wrecker.
$350 + Offering V1 ...Get a Works Components angle headset and this:
I've been thinking the same. Perhaps a slight tweak for fun. I'm pretty happy with my current offering w/push shock. I don't feel like investing in new rear wheelsets yet(157).Cascade link was designed for the current Offering. Do we know if it works with the v2?
Looking at:
Ohlins TTX22M
Fox DHX2
CC Kitsuma coil
Anyone input is appreciated.
Aggressive trail riding in Seattle (PNW) area. 177lb rider. 150mm Lyrik up front. Probably bump up to 160 if I go through with a coil. Coming off stock RS SuperDeluxe which is good on small chatter and has great pop, but doesn't like high speed mid-sized and bigger chunk.
Figure the Delta is progressive enough to make any work. But don't want to turn this bike into a couch.
CheerS
What sutter2k said - I'm 180 and have an Offering and a GuerillaGravity Smash - the Evil feeling is more playful and the GG more plush, but the shock adjustments and tires make a huge difference - lots of variables. Both great bikes.Push 11/6 here. 525lb spring, I weigh 205.
Also an aggressive trail rider. I say the bike is poppy and pedals well.
I also have a guerrilla gravity megatrail with fox dhx2 and rockshox super deluxe coil, and fox dpx2. That bike is great in the bike park, but more numb as far as poppiness or standing to pedal regardless of shock. Granted the tires on it zap some energy as well.
i had 3 11-6 then went to cane creek, my buddy got the new version as well. rode 11-6 and cc back to back a few times, went with cc, climbs better and is cheaper. i do think the 11-6 may be a bit burlier though.I'm looking to do a shock upgrade but wondering if I should hold off until the V2 is released to see if the shock size is different. I definitely want to be able to transfer over to the new frame.
Looking to get the cane creek suspension going.
