My buddy just got an 04 heckler with 5th element. Compared to my 03, his shock spring seems significantly longer by maybe by about 1 inch. The shock itself seems about the same, its the spring that seems longer. You can easily tell by where the spring sits on the shock. Another difference is his rebound adjustment is a knob that can be turned with your finger vs mine rebound adjuster which requires a allen wrench.
Anyway, his setup seems much more plush than mine with more "usable" travel and a faster rebound. My rebound is pretty slow even with on the lowest position. Anyone know why the difference in shock spring lengths for the 03 and 04? If I put a longer spring on my shock ( Mine spring is currently 300 lbsx 2 inches) will it work better?
Before everyone goes off on my shock settings not being correct, I've followed both SC and Progressives instructions (which differ- progessive says use a heavier spring for my weight) and switched between both a 375 and 300 spring. My friend's spring is also a 300lb but I'm not sure the length.
