Pardon my boldness but, I thought that posts regarding pro's, con's, and issues with the Cake deserved a "definitive" thread (as opposed to being headed under "Stability with a Cake" or "New to mtn biking, just bought Cake DLX2"). So I propose that we use this thread for reviews, technical questions, etc. It would be great to have all that useful Cake info. consolitdated. Feel free to post, or not.
The Loctite issue:
I have just returned from my LBS where I sat in on the repair (loose rear triangle after three rides). It took him about 1/2 hour. It was good to see because it's essentially the process we'll be using to replace bearings when they wear out. I could go into detail but, more to the point, the bearings had been "set" with Loctite but, hardly enough to do the job. GF/ Trek designed the bearing housing to allow the bearings to be hand-placed (as opposed to the typical press-fit) probably to aid in the assembly process. That is to say, the bearings are as easy to remove as a key from a lock. But, for that reason, liberal application of Loctite was also required. We removed the bearings, applied the 680 retaining compound to the outer race of the bearing and the inside of the bearing houseing, replaced the bearings, and that was that. The compound takes 24 hours to fully cure. There is no play in the rear triangle now though, I have yet to get out for a ride. I'll keep everyone posted.
Anyone with similar experiences or other Cake issues please reply to this thread.
The Loctite issue:
