1 - 6 of 6 Posts
· Registered
besides the news that EXT works on an air shock, the german guys from Chickadeehill presented their air shock with a floating piston twin airchamber design:
http://instagr.am/p/CYpInC0tKv3/
screenshot of the insta post:
Line Cylinder Gas Auto part Machine
seems like sort of a ring piston inbetween the two airsleeves, the valve at the eyelet pressurizes the main chamber, the 2. valve at the sealhead the IRT chamber.
· Registered
Discussion Starter · #3 ·
their first prototype of an IRT was for a RS Totem in 2012 ;)
· Registered
Interesting that they decided to go production with this.
Personally, I've also experimented this and in the end I think it's not worth it, for a rear shock.
http://instagr.am/p/B31N4DyjeVF/
Automotive tire Bicycle part Gas Machine Bumper
On forks, the two-stage positive chamber was a good way to significantly mitigate the effects of the undersized negative air chamber. At least, before better options started showing up.
But on rear shocks, once the suspension linkage is tuned to obtain, in combination with the shock's characteristics, a linear-to-progressive force curve, there's no point. The initial portion of travel can't get more supple, and I thought the extra mid-stroke support had benefits in some instances but was a problem on the steeps.
Rectangle Slope Parallel Plot Font
Different situation for forks. Even with a proper linear-to progressive air spring, I find the extra mid-stroke support of a dual stage positive chamber is a significant improvement without downsides.
· Registered
http://instagr.am/p/B31N4DyjeVF/ View attachment 1965531
Yes,No Matter what slight difference between Solo and Double positive Air Chambers a Graph Shows. In real world you can experience a very noticeable difference in Ride Feel.besides you can tune IT to your likings while you are Stuck With one curve at an solo Air Setup.
1 - 6 of 6 Posts
